Hi there,
I am exporting the final animated results using PDF extension Descargar Snow Bros APK. The problem I have is that when I am trying to edit this file using any other software i.e. draw plus I could not since the exported file appears as a picture. My question is that is there any possibility to export the final mesh as it is (as continuous lines, not a picture)?
Kind regards
I assume that do you want to export your 3D model, not a a 3D model but in a 2D projection image,
and do you want a vectorial description, not a bitmap.
use
Files->Print to file->PS/EPS/PDF Vectorial
Try also de PS or EPS formats.
For bitmap image use
Files->Print to file->PS/EPS/PDF Screen
png
gif
jpg
tiff
and for 3D formats
vrml
stl
obj
and the Files->Export formats
