[GiDlist] Algorithm used in Smooth Contour Fill
Hello:
Can you please help with following questions:
  1. What is algorithm used for Smooth Contour Fill?
  2. What are equations used for calculating Si, Sii, Siii from 6 components
    of Matrix type in post-processing?
Thank you in advance.
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100120/07c6582c/attachment.htm
explained in GiD’s help and in :
http://www.gidhome.com/support_team/gidbeta/gid125.html#POSTPROCESS%20RESULT
S%3ESmooth%20Contour%20Fill
http://www.gidhome.com/support_team/gidbeta/gid148.html#POSTPROCESS%20DATA%2
0FILES%3EPostprocess%20results%20format:%20ProjectName.post.res%3EResult%20b
lock
1.- foreach element incident to a node, the gauss point results are
extrapolated to the nodes. Then from the set of extrapolated values for that
node,
GiD uses:
  • the minimum value if ‘Options–Contour–Smoothing type–minimum value’
    is selected;
  • the maximum value if ‘Options–Contour–Smoothing type–maximum value’
    is selected;
  • the mean value if ‘Options–Contour–Smoothing type–mean value’ is
    selected ( == sum(all values) / NumValues)
    2.- When a stress matrix is read, GiD calculates the eigen vectors and eigen
    values of this matrix, then sort them according to the eigen values, being
    Si the biggest value and Siii the smallest one.
    Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Thanh Chau Dinh
Enviado el: miércoles, 20 de enero de 2010 16:59
Asunto: [GiDlist] Algorithm used in Smooth Contour Fill
Hello:
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100125/92180ef8/attachment.htm
2- Eigenvalues/eigenvector are calculated with an iterative Jacobi method
(see “Numerical Recipes in C” at http://www.nrbook.com/a/bookcpdf.php , chapter 11.1)
Sent: Monday, January 25, 2010 4:05 PM
Subject: RE: [GiDlist] Algorithm used in Smooth Contour Fill
http://www.gidhome.com/support_team/gidbeta/gid125.html#POSTPROCESS%20RESULTS>Smooth%20Contour%20Fill
http://www.gidhome.com/support_team/gidbeta/gid148.html#POSTPROCESS%20DATA%20FILES>Postprocess%20results%20format:%20ProjectName.post.res>Result%20block
1.- foreach element incident to a node, the gauss point results are extrapolated to the nodes. Then from the set of extrapolated values for that node,
GiD uses:
  • the minimum value if ‘Options–Contour–Smoothing type–minimum value’ is selected;
  • the maximum value if ‘Options–Contour–Smoothing type–maximum value’ is selected;
  • the mean value if ‘Options–Contour–Smoothing type–mean value’ is selected ( == sum(all values) / NumValues)
    2.- When a stress matrix is read, GiD calculates the eigen vectors and eigen values of this matrix, then sort them according to the eigen values, being Si the biggest value and Siii the smallest one.
    Miguel Pasenau
IMPORTANT NOTICE
De: gidlist-admin at gatxan.cimne.upc.edu [mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Thanh Chau Dinh
Hello:
  2. What are equations used for calculating Si, Sii, Siii from 6 components of Matrix type in post-processing?
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100125/8efac39f/attachment.htm
Hello:
Thanks for your clear reply.
Thanh
On Tue, Jan 26, 2010 at 12:05 AM, Miguel Adolfo Pasenau de Riera
_http://www.gidhome.com/support_team/gidbeta/gid125.html#POSTPROCESS%20RESULTS>Smooth%20Contour%20Fill_
_http://www.gidhome.com/support_team/gidbeta/gid148.html#POSTPROCESS%20DATA%20FILES>Postprocess%20results%20format:%20ProjectName.post.res>Result%20block_
node,
GiD uses:
- the minimum value if ‘Options–Contour–Smoothing type–minimum value’
is selected;
- the maximum value if ‘Options–Contour–Smoothing type–maximum value’
is selected;
- the mean value if ‘Options–Contour–Smoothing type–mean value’ is
Miguel Pasenau
IMPORTANT NOTICE
gidlist-admin at gatxan.cimne.upc.edu] *En nombre de *Thanh Chau Dinh
Hello:
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100126/397394f2/attachment.htm
