[GiDlist] Calculate the mesure of a volume
Dear Sir Madame,
I am a GID customer, I use your software as pre an postprocessor for
beasy corrosion software.
I have a simple problem:
I create a volume enclosed between some surfaces, but I can’t find the
way to measure it.
Thank you in advance for your answer
Best Regards
Fabio Scherillo
Utilities-Mass-Volumes…
and select the geometric volumes or mesh elements to know its approximated
volume.
Sent: Friday, June 15, 2012 8:50 PM
Subject: [GiDlist] Calculate the mesure of a volume
Dear Sir Madame,
way to measure it.
Best Regards
Fabio Scherillo
Can I have two post processing %1.post.res files that are written by
two different codes? Or can I merge them together by a command in the
batch file?
Thank You
Yes, you can have several .post.res (or .post.msh) files, and can read them
in postprocess with Files-Open multiple… and select the files you want.
You can also have a file named ‘model.post.lst’ with the list of the
.post.res files to be read, and then instead of selecting a lot of files
you only need to select this one (and changing from pre to post this file
will be automatically read)
See help 'GiD customization-postprocess data files-postprocess list file
From: “Farzam, Arash” farzam at ostatemail.okstate.edu
Sent: Friday, June 15, 2012 11:09 PM
Subject: [GiDlist] More than one post processing files
batch file?
Thank You
