[GiDlist] Can't make gidpost.lib file
Dear members,
I’m a new user of Gid. Recently I would like to make gidpost.lib per the
GiD instruction.
Unfortunately it could not successfully generated.
My computer OS: WinXP with Visual Studio 2010.
I’d run vcvars32.bat prior namake execution. But it still can’t work.
The following is the output message:
No configuration specified. Defaulting to Release.
cl.exe /nologo /ML /W3 /GX /O2 /I “..\source” /I “..” /D “WIN32” /D
“VIS
UAL_CPLUSPLUS” /D “NDEBUG” /D “_MBCS” /D “_LIB” /Fp".\Release\gidpost.pch"
/YX /
Fo".\Release\" /Fd".\Release\" /FD /c ..\source\zlibint2.c
‘cl.exe’ 不是內部或外部命令、
可執行的程式或批次檔。 (cl.exe is not internal or external command, executable program
or batch file)
NMAKE : fatal error U1077: ‘cl.exe’ : return code ‘0x1’
Stop.
I will be deeply appreciated, if anyone can help.
Thanks in advance.
TY WU
institute of nuclear energy research
tywu at iner.gov.tw
tywuda at gmail.com
I
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120526/7178256e/attachment.htm
Dear all members,
I’ve solved the problem of not being able to make gidpost.lib.
However, I encountered another problem –
the gidpost.lib can’t successfully compiled with the example file,
testpostfor.f
The following message was dumped by Compaq fortran:
--------------------Configuration: test - Win32 Debug--------------------
Linking…
dfor.lib(for_init.obj) : warning LNK4078: multiple “.CRT” sections found
with different attributes (C0300040)
LINK : warning LNK4098: defaultlib “LIBCMT” conflicts with use of other
libs; use /NODEFAULTLIB:library
gidpost.lib(gidpost.obj) : error LNK2001: unresolved external symbol
___security_cookie
gidpost.lib(gidpostInt.obj) : error LNK2001: unresolved external symbol
___security_cookie
gidpost.lib(zlibint1.obj) : error LNK2001: unresolved external symbol
___security_cookie
___CxxFrameHandler3
@__security_check_cookie at 4
Debug/test.exe : fatal error LNK1120: 3 unresolved externals
Error executing link.exe.
test.exe - 8 error(s), 2 warning(s)
Any comments will be appreciated. Thanks.
Tung-Yueh Wu
2012/5/26 gidlist-request at listas.cimne.upc.edu
Today’s Topics:
1. Can’t make gidpost.lib file (Tong-yue Wu)
Message: 1
Date: Sat, 26 May 2012 14:38:04 +0800
Subject: [GiDlist] Can’t make gidpost.lib file
Message-ID:
CAPN3_V9mze=ZJsYr5+0bzJzDonvoq38ThaaD4tw=bYs2CiX3Eg at mail.gmail.com
Content-Type: text/plain; charset=“big5”
Dear members,
GiD instruction.
"VIS
_UAL_CPLUSPLUS" /D “NDEBUG” /D “_MBCS” /D "LIB" /Fp".\Release\gidpost.pch"
/YX /
‘cl.exe’ ???
??? (cl.exe is not internal or external command, executable program
or batch file)
Stop.
Thanks in advance.
TY WU
tywu at iner.gov.tw
tywuda at gmail.com
I
URL:
_http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120526/7178256e/attachment-0001.htm_
End of GiDlist Digest, Vol 22, Issue 8
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120528/88770878/attachment.htm
If do you have compiled the gidpost.lib library with the flag /GS (“buffer security check”) try to recompile the library without this flag.
I recommend you also to compile the multithread non-dll version of the library, to avoid dependencies of MSVCxx runtime dlls
e.g. use /MT instead /MD (C++ - Code Generation - Runtime Library)
and in the fortran project use Fortran - Libraries - runtime library - Multithreaded (maybe these options doesn’i exists in your Compaq compiler, I’ve tried the Intel Fortran compiler 10.1)
Sent: Monday, May 28, 2012 9:14 AM
Subject: Re: [GiDlist] GiDlist Digest, Vol 22, Issue 8
Dear all members,
the gidpost.lib can’t successfully compiled with the example file, testpostfor.f
Linking…
dfor.lib(for_init.obj) : warning LNK4078: multiple “.CRT” sections found with different attributes (C0300040)
LINK : warning LNK4098: defaultlib “LIBCMT” conflicts with use of other libs; use /NODEFAULTLIB:library
gidpost.lib(gidpost.obj) : error LNK2001: unresolved external symbol ___security_cookie
gidpost.lib(gidpostInt.obj) : error LNK2001: unresolved external symbol ___security_cookie
gidpost.lib(zlibint1.obj) : error LNK2001: unresolved external symbol ___security_cookie
gidpost.lib(gidpost.obj) : error LNK2001: unresolved external symbol ___CxxFrameHandler3
gidpost.lib(gidpost.obj) : error LNK2001: unresolved external symbol @__security_check_cookie at 4
gidpost.lib(gidpostInt.obj) : error LNK2001: unresolved external symbol @__security_check_cookie at 4
gidpost.lib(zlibint1.obj) : error LNK2001: unresolved external symbol @__security_check_cookie at 4
Tung-Yueh Wu
Today’s Topics:
Message: 1
Message-ID:
Dear members,
GiD instruction.
“VIS
/YX /
‘cl.exe’ ???
or batch file)
Stop.
Thanks in advance.
TY WU
tywu at iner.gov.tw
tywuda at gmail.com
I
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120526/7178256e/attachment-0001.htm
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120529/a9ae27bd/attachment.htm
