[GiDlist] centered structured mesh
Dear members,
I would like to make a simple centered structured mesh (see attachment) with center at (0,0) but Gid crashes.
Any help will be greatly appreciated,
NGDau
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100209/4e571234/attachment.htm
Type: application/zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100209/4e571234/attachment.zip
Dear NGDau,
As you said, this is a irregular behaviour. We have fixed the bug, and it
will be available in the next beta version.
By the moment, you can avoid this bug by assigning by hand the number of
divisions manually to the contour lines of the surface, so as the number of
the divisions of all the lines is more than three times the number of radial
divisions of the surface (in your case 5).
Kind regards,
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per
IMPORTANT NOTICE
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Dau Nguyen Van
Enviado el: martes, 09 de febrero de 2010 17:20
Asunto: [GiDlist] centered structured mesh
Dear members,
NGDau
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100209/866e1a18/attachment.htm
Dear Abel,
Many thanks for your quick response.
NGDau
— On Wed, 2/10/10, Abel Coll abelcs at cimne.upc.edu wrote:
Subject: RE: [GiDlist] centered structured mesh
Date: Wednesday, February 10, 2010, 12:32 AM
Dear NGDau,
and it will be available in the next beta version.
of divisions manually to the contour lines of the surface, so as the number of
Kind regards,
ABEL
Abel Coll
CIMNE
  • International Center for Numerical Methods in Engineering
    Campus Nord UPC
    Barcelona
    AVISO
    IMPORTANTE
registrarán en un fichero para facilitar la gestión de las
comunicaciones de CIMNE. Se pueden ejercitar los derechos de acceso,
rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras
oficinas de CIMNE, Gran Capitán s/n,
España.
AVÍS IMPORTANT
missatge es registraran en un fitxer per facilitar la gestió de les
comunicacions del CIMNE. Es poden exercir els drets d
’ accés, rectificació, cancel·lació i oposició, per
IMPORTANT
NOTICE
processed confidentially and stored in a file property of CIMNE in
order to manage corporate communications. You may exercise the right of
access, rectification, deletion and objection by letter sent to CIMNE, Gran
Capitán, Edificio C1 - Campus Norte UPC, 08034
Barcelona ,
Spain .
Van
Para:
mesh
Dear members,
crashes.
appreciated,
NGDau
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100210/c21c02e8/attachment.htm
Hi All
I am trying out the 9.0.2 on ubuntu karmic&lucid. The problem I have
encountered is that the drop down menu bar (the bar with help on the
right), and any widgets opened by it are tiny. Most words are
impossible to read in fact. Has anyone else encountered this problem
and/or knows the solution?
Cheers
Gerard
I found the answer is to edit the file ~/.gidDefaults and change:
NormalFont Helvetica 10 normal roman
to
NormalFont Helvetica 20 normal roman
Cheers
Gerard
Gerard Gorman wrote:
Hi All
Cheers
Gerard
GiDlist at gid.cimne.upc.edu
Dear GID team,
I am using a results file with multiple steps in it. In each step I am
writing different meshes and different results, in order to view the
results corresponding to an analysis with adaptive remeshing.
My question is the following: is it possible to animate only one of the
steps, using something like the static animation profile facility in the
animate window?
Many thanks,
Jose
Fonts can be graphically changed from the “Preferences-Fonts” Window
(Utilities-Preferences menu)
Sent: Thursday, February 11, 2010 9:49 AM
Subject: Re: [GiDlist] tiny menu bar
to
Cheers
Gerard
Hi All
Cheers
Gerard
