[GiDlist] Curved triangles and straight quadrilaterals
Curve triangles and straight quadrilaterals
Hi everyone,
I’m using GiD 7.4.7b for windows.
I have the following problem:
Surfaces with curved contours meshed with triangles have curved elements on the curved
contour lines, but if meshed with quadrilaterals the elements on the curved contours have
straight lines.
Other data:
  • I use “Draw quadratic elements as curves”
  • I mesh 2D surfaces embedded in 3D
  • The mesh is quadratical
    Am I doing or interpreting something wrong?
    Thanks for any help.
Kind regards
Andrea
Andrea Calaon
Ashurst Lodge, Ashurst
Southampton, Hampshire
SO40 7AA, UK
Fax office: +44 23 80 292 853
Mobile: +44 7766 488 225
E-mail: andrea at beasy.com
The quadratic nodes of quadrilaterals are located over the geometric
entities (curved), same as triangles.
Are you sure than your mesh is quadratic, and are drawing the elements as
curved?
I tried with GiD 7.4.9b and it works ok.
Sent: Thursday, October 14, 2004 5:16 PM
Subject: [GiDlist] Curved triangles and straight quadrilaterals
Hi everyone,
the curved
contours have
straight lines.
Other data:
Kind regards
Andrea
Andrea Calaon
SO40 7AA, UK
Dear Enrique,
I send you 4 pictures showing what kind of mesh I get in 3D and 2D cases.
With quadrilaterals the location of the nodes is on the straight lines.
I set the mesh to quadratic thorough the menu and tried with the command “Meshing
quadratic” as well.
In preferences the “as curved” choice is selected.
I checked the coords: the nodes are on the straight lines in case of quadrilaterals and
on the curve in case of triangles.
On a Linux machine with GiD 7.4.7b it works fine.
Kind regards
Andrea
curved?
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any another MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
---- File information -----------
File: curved.jpg
Date: 14 Oct 2004, 16:09
Type: JPEG-image
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041015/f309278e/attachment.jpg
File: straight.jpg
Date: 14 Oct 2004, 16:11
Type: JPEG-image
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041015/f309278e/attachment-0001.jpg
File: curved_plane.jpg
Date: 15 Oct 2004, 12:40
Type: JPEG-image
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041015/f309278e/attachment-0002.jpg
File: flat_plane.jpg
Date: 15 Oct 2004, 12:39
Type: JPEG-image
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041015/f309278e/attachment-0003.jpg
