[GiDlist] EOF too early
Hello GiD Team,
My *.post.res file is as follows:
GiD Post Results File 1.0
Result “Displacements” “Load Analysis” 1 Vector OnNodes
ComponentNames “Disp_X”, “Disp_Y”, “Disp_Z”
values
1 … … …
2 … … …
810 … … …
end values
I want to plot the deformed shape of the plate, but the error occurs: Found EOF too early: in this line: 824 - Reading Results.
I can interpretate some results, but I am afraid they are not read well. I have attached res and msh files for the illustration.
When I read only the mesh without results, it is working okay.
Did I do something wrong? Btw, thanks for the advice about managing the menus.
Best regards from Bochum,
Miroslav Marjanovic
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131018/ed34d811/attachment-0001.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131018/ed34d811/attachment-0002.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131018/ed34d811/attachment-0003.obj
the problem is that your results file starts with comments lines instead of
starting with the line ‘GiD Post Results File 1.0’.
The line ‘GiD Post Results File 1.0’ should be the first line of the results
file ‘*.res’,
then you can add comment lines or any other results definition.
If the first line has any other definition, then the file will be read using
a very old format ( for backwards compatibility), causing some strange
things as creating phantom results like
“ComponentNames …”, “end values”, “GiD Post Results…”, etc.
thanks,
best regards,
Miguel Pasenau
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mire Marjanovic
Enviado el: viernes, 18 de octubre de 2013 22:09
Asunto: [GiDlist] EOF too early
Hello GiD Team,
values
1 … … …
2 … … …
810 … … …
end values
menus.
Miroslav Marjanovic
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131021/295fa171/attachment-0001.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131021/295fa171/attachment-0002.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131021/295fa171/attachment-0003.obj
