[GiDlist] error In Contact volumes
Hi
I would like to know what is this error about:
“FigPlex::set_at. Repeated indes 468 in FigPlex”
I’m trying to mesh some contact volumes (including hexa and prisms)
and I get this error.
The procedure I did is described as follows:
  1. I made an offset copy of the surfaces and I check in the box to
    create contact volumes
  2. I assigned to surfaces a structured mesh with the number of
    divisions I wanted.
  3. I try to mesh but I got the error and then the software does not respond.
    GiD Version: 9.0.4
Thanks for the help.
Best Regards
Cristian NIETO
PhD Student
Laboratoire de Mécanique de Sols, Structures et Materiaux - LMSSMat
Ecole Centrale Paris - Coyne et Bellier. Bureau d’ingénieurs Conseils
Paris - France
Dear Cristian,
We should try to reproduce this error to solve it. Please, can you send me
the model? (you can send it to my mail adress (abelcs at cimne.upc.edu) instead
to the GiDlist).
Kind regards,
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per
IMPORTANT NOTICE
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Cristian Nieto
Gamboa
Enviado el: miércoles, 10 de marzo de 2010 20:34
Asunto: [GiDlist] error In Contact volumes
Hi
I’m trying to mesh some contact volumes (including hexa and prisms) and I
get this error.
  1. I made an offset copy of the surfaces and I check in the box to create
    contact volumes 2. I assigned to surfaces a structured mesh with the number
    of divisions I wanted.
  2. I try to mesh but I got the error and then the software does not respond.
    GiD Version: 9.0.4
Best Regards
Cristian NIETO
PhD Student
Laboratoire de Mécanique de Sols, Structures et Materiaux - LMSSMat Ecole
Centrale Paris - Coyne et Bellier. Bureau d’ingénieurs Conseils Paris -
France
GiDlist at gid.cimne.upc.edu
I have a folder with all my Gid’s files. When I’m going to open any file, it doesn’t work and the follow message appears: the file doesn’t exist or can’t be read. The files are not empty because they have memory space. What I have to do to solve that problem?
Thank you for helping me.
Maria Gonzalez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100315/e1585564/attachment.htm
Which files do you have inside the .gid folder of some example?
The .geo is the most important file, it contain the geometry
If you are unable to open it, compress the .gid folder in a zip and send me (escolano at cimne.upc.edu ) to have a look
Which version of GiD are you using? (see Help-About)
Sent: Monday, March 15, 2010 10:14 PM
Subject: [GiDlist] Question about a folder
Maria Gonzalez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100316/8c496551/attachment.htm
Hello.
I´m sending you the compressed .gid folder of one of my files.
The gid version is 8.0.2.
Thanks.
Maria G.
-----Original Message-----
Sent: Tue, Mar 16, 2010 5:38 am
Subject: Re: [GiDlist] Question about a folder
Maria Gonzalez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100316/e7062689/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100316/e7062689/attachment.obj
Hi Maria,
The problem is that you renamed the gid folder from Occipital.gid to OccipitalDic09.gid and then GiD didn’t found the rest of the files:
The .gid folder and its internal gid files .geo, etc must use the same root name (ye.g. you must rename also Occipital.geo and others to OccipitalDic09.geo)
Sent: Tuesday, March 16, 2010 3:40 PM
Hello.
Thanks.
Maria G.
Maria Gonzalez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100316/1b879825/attachment.htm
