[GiDlist] Extracting results from contour fills
Hi everyone,
I have a quite large 3D mesh and I’m interested in the results in a specific
cut plane. The plane doesn’t cross any node so I guess the contour fill is
created by some kind of interpolation between values at the nodes. Is it
possible to get the numerical values in a grid of points in the cut plane?
I’d like to repeat a question no one replied to yet: when plotting line
grapsh GiD doesn’t seem to do any interpolation between values at the nodes.
Midside nodes resultes aren’t displayed either. Is it possible to get some
interpolation between value at the nodes?
Thank you very much,
NL.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100203/c3cee41b/attachment.htm
You can do the cut, and convert it to set (there is a flag to atomatically convert cuts to sets)
A cut converted to set is like other meshes, you can list its nodes, or export it to an ASCII file to easily read it.
A comment: new 9.2.7b beta version include a new feature in postprocess to integrate an scalar or vector result on a selected set, maybe is what you want to obtain in your cut plane.
About the line graphs plotting quadratic nodes, I don’t know if they could be forced to be calculated or plotted, if not we can add this to the list of thinks to do for next versions…
Sent: Wednesday, February 03, 2010 7:32 PM
Subject: [GiDlist] Extracting results from contour fills
Hi everyone,
I have a quite large 3D mesh and I’m interested in the results in a specific cut plane. The plane doesn’t cross any node so I guess the contour fill is created by some kind of interpolation between values at the nodes. Is it possible to get the numerical values in a grid of points in the cut plane?
I’d like to repeat a question no one replied to yet: when plotting line grapsh GiD doesn’t seem to do any interpolation between values at the nodes. Midside nodes resultes aren’t displayed either. Is it possible to get some interpolation between value at the nodes?
NL.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100203/0ed0e269/attachment.htm
