[GiDlist] GiD Geometry Toolbar
Hello GiD team,
Regarding the “Geometry and view toolbar” - Is it possible to configure the
toolbar so that it appears only in the pre-processing and is hidden in the
post-processing? The options in “configure toolbar” is always applied to
both pre and post processing.
Shriram
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100712/d4b553ca/attachment.htm
Hello Shiram,
This option doesn’t exists now.
We can think to add this feature for next betas.
Sent: Monday, July 12, 2010 10:10 PM
Subject: [GiDlist] GiD Geometry Toolbar
Hello GiD team,
Regarding the “Geometry and view toolbar” - Is it possible to configure the toolbar so that it appears only in the pre-processing and is hidden in the post-processing? The options in “configure toolbar” is always applied to both pre and post processing.
Shriram
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100713/37ba6b7e/attachment.htm
Hi all,
I need to integrate some results from my analysis and I need to do it by
hand. As I’ve seen GiD Postprocess function “Integrate” gives accurate
results. Is it possible to know how it works? (which integration method,
algorithm, etc)
Nunzio.
PS: y enhorabuena por la copa.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100713/ec946f07/attachment.htm
the integrate option in GiD, after selecting a scalar value, GiD averages
the result for the element and multiplies it by the element size,
accumulating the results for all the elements of the selected set.
For a vector results, GiD averages the scalar product of the result and the
normal for the element.
There is an option to do the integration only for the current step or for
all the steps of the analysis. With this last option, a graph showing this
integration value evolution is also created.
For gauss points:
  • for volume and surface sets only 1 gauss point is supported
  • for cut sets, the integration is done over the smoothed gaussian results
    to the nodes.
    best regards,
    Miguel Pasenau
    De: gidlist-admin at gid.cimne.upc.edu [mailto:gidlist-admin at gid.cimne.upc.edu]
    En nombre de Nunzio Losacco
    Enviado el: martes, 13 de julio de 2010 10:22
    Asunto: [GiDlist] Integrate results - how does it work?
    Hi all,
    algorithm, etc)
    Nunzio.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100713/756ef1db/attachment.htm
Dear Nunzio,
May be I can clarify a little bit Miguel’s answer.
By the moment GiD only calculates the numerical integration on linear
elements. For this reason, the classical way of integrating numerical
results on an element (taking into account the weights of the Gauss points,
the nodal values and the shape functions) can be expressed (simplifying) as
the average of the values of the result on the nodes of the element (as
Miguel said in the previous mail). The integration for non-linear elements
is not available yet, and it will use this classical way for numerical
integration.
This option is only available (by now) if the results (inside GiD project)
are in nodes (not in Gauss points), except the case Miguel pointed out (only
in case of results in one Gauss point).
Kind regards,
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per
IMPORTANT NOTICE
En nombre de Miguel A. Pasenau de Riera
Enviado el: martes, 13 de julio de 2010 16:25
Asunto: RE: [GiDlist] Integrate results - how does it work?
For gauss points:
    to the nodes.
    best regards,
    Miguel Pasenau
    Hi all,
    algorithm, etc)
    Nunzio.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100714/c9b2f067/attachment.htm
Thank you very much for your replies guys.
N.
2010/7/14 Abel Coll abelcs at cimne.upc.edu
Dear Nunzio,
as the average of the values of the result on the nodes of the element (as
integration.
Kind regards,
ABEL
AVISO IMPORTANTE
en un fichero para facilitar la gestión de las comunicaciones de CIMNE. Se
AVÍS IMPORTANT
registraran en un fitxer per facilitar la gestió de les comunicacions del
CIMNE. Es poden exercir els drets d’accés, rectificació, cancel·lació i
oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n,
Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
gidlist-admin at gid.cimne.upc.edu] *En nombre de *Miguel A. Pasenau de Riera
For gauss points:
- for volume and surface sets only 1 gauss point is supported
- for cut sets, the integration is done over the smoothed gaussian results
to the nodes.
best regards,
Miguel Pasenau
gidlist-admin at gid.cimne.upc.edu] *En nombre de *Nunzio Losacco
Hi all,
algorithm, etc)
Nunzio.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100721/fff8a78a/attachment.htm
