[GiDlist] GiDlist Digest, Vol 22, Issue 10
Hi Enrique Escolano,
I did not use the flag /GS when I was compiling gidpost.lib.
But, several *.obj files were generated, in addition to the gidpost.lib
file.
I don’t know if this is normal or not.
I have compiled the file using Intel Fortran V10.0, but still not work.
Thank you very much for your help.
Best,
TY Wu
2012/5/29 gidlist-request at listas.cimne.upc.edu
Today’s Topics:
1. Re: GiDlist Digest, Vol 22, Issue 8 (Enrique Escolano)
Message: 1
Date: Tue, 29 May 2012 10:46:24 +0200
Subject: Re: [GiDlist] GiDlist Digest, Vol 22, Issue 8
Message-ID: 9C4AF1AB9AB84B549FED5442525C3950 at mediador
Content-Type: text/plain; charset=“iso-8859-1”
If do you have compiled the gidpost.lib library with the flag /GS ("buffer
security check") try to recompile the library without this flag.
I recommend you also to compile the multithread non-dll version of the
library, to avoid dependencies of MSVCxx runtime dlls
e.g. use /MT instead /MD (C++ - Code Generation - Runtime Library)
and in the fortran project use Fortran - Libraries - runtime library -
Multithreaded (maybe these options doesn’i exists in your Compaq compiler,
I’ve tried the Intel Fortran compiler 10.1)
Sent: Monday, May 28, 2012 9:14 AM
Dear all members,
I’ve solved the problem of not being able to make gidpost.lib.
However, I encountered another problem –
the gidpost.lib can’t successfully compiled with the example file,
testpostfor.f
The following message was dumped by Compaq fortran:
--------------------Configuration: test - Win32 Debug--------------------
Linking…
dfor.lib(for_init.obj) : warning LNK4078: multiple “.CRT” sections found
with different attributes (C0300040)
LINK : warning LNK4098: defaultlib “LIBCMT” conflicts with use of other
libs; use /NODEFAULTLIB:library
gidpost.lib(gidpost.obj) : error LNK2001: unresolved external symbol
___security_cookie
gidpost.lib(gidpostInt.obj) : error LNK2001: unresolved external symbol
___security_cookie
gidpost.lib(zlibint1.obj) : error LNK2001: unresolved external symbol
___security_cookie
___CxxFrameHandler3
@__security_check_cookie at 4
Debug/test.exe : fatal error LNK1120: 3 unresolved externals
Error executing link.exe.
test.exe - 8 error(s), 2 warning(s)
Any comments will be appreciated. Thanks.
Tung-Yueh Wu
2012/5/26 gidlist-request at listas.cimne.upc.edu
Today’s Topics:
1. Can’t make gidpost.lib file (Tong-yue Wu)
Message: 1
Date: Sat, 26 May 2012 14:38:04 +0800
Subject: [GiDlist] Can’t make gidpost.lib file
Message-ID:
CAPN3_V9mze=ZJsYr5+0bzJzDonvoq38ThaaD4tw=
bYs2CiX3Eg at mail.gmail.com
Content-Type: text/plain; charset=“big5”
Dear members,
I’m a new user of Gid. Recently I would like to make gidpost.lib per the
GiD instruction.
Unfortunately it could not successfully generated.
My computer OS: WinXP with Visual Studio 2010.
I’d run vcvars32.bat prior namake execution. But it still can’t work.
The following is the output message:
No configuration specified. Defaulting to Release.
cl.exe /nologo /ML /W3 /GX /O2 /I “..\source” /I “..” /D “WIN32”
/D
"VIS
_UAL_CPLUSPLUS" /D “NDEBUG” /D “_MBCS” /D "LIB"
/Fp".\Release\gidpost.pch"
/YX /
Fo".\Release\" /Fd".\Release\" /FD /c ..\source\zlibint2.c
‘cl.exe’ ???
??? (cl.exe is not internal or external command, executable
program
or batch file)
NMAKE : fatal error U1077: ‘cl.exe’ : return code ‘0x1’
Stop.
I will be deeply appreciated, if anyone can help.
Thanks in advance.
TY WU
institute of nuclear energy research
tywu at iner.gov.tw
tywuda at gmail.com
I
URL:
_http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120526/7178256e/attachment-0001.htm_
End of GiDlist Digest, Vol 22, Issue 8
URL:
_http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120529/a9ae27bd/attachment-0001.htm_
End of GiDlist Digest, Vol 22, Issue 10
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120530/a3e94dcb/attachment.htm
