URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120702/b4d9264e/attachment.htm
Hi all,
with all GiD versions I’ve tried (9.x, 10.x, 11.x) the “Create Result”
option in the “Window” menu of postprocessing is not working properly.
Namely I have noted two issues:
When I want to pick an operand result from a long list I have to click
“..More…” on the dropdown menu. Choosing the result from the “View
Results and Deformation” window which popups thereafter has the only effect
of changing the DISPLAYED results and does not change the result chosen as
“Create Result” operand, instead. -
Whenever I try to create a new result from results defined at Gauss
points I have the following error:
found an error
while executing
“GiD_Result create {*}$res_dst”
(procedure “PCRApply” line 409)
invoked from within
“PCRApply”
invoked from within
".gid.wPostCrearResultado.but.
apply invoke "
invoked from within
".gid.wPostCrearResultado.but.apply instate !disabled {
invoke } "
invoked from within
“.gid.wPostCrearResultado.but.apply instate pressed {
state !pressed; .gid.wPostCrearResultado.but.apply instate !di…”
(command bound to event)
Is this ever going to be solved?
NL
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120709/77aa4603/attachment.htm
Hello Nunzio,
We fixed this bug in the last developer version 11.1.0d, that is available for download now at www.gidhome.com
Sent: Monday, July 09, 2012 4:06 PM
Subject: [GiDlist] “Create Results” does not work properly
Hi all,
with all GiD versions I’ve tried (9.x, 10.x, 11.x) the “Create Result” option in the “Window” menu of postprocessing is not working properly. Namely I have noted two issues:
When I want to pick an operand result from a long list I have to click “..More…” on the dropdown menu. Choosing the result from the “View Results and Deformation” window which popups thereafter has the only effect of changing the DISPLAYED results and does not change the result chosen as “Create Result” operand, instead.
Whenever I try to create a new result from results defined at Gauss points I have the following error:
found an error
while executing
invoked from within
“PCRApply”
invoked from within
apply invoke "
invoked from within
".gid.wPostCrearResultado.but.apply instate !disabled { .gid.wPostCrearResultado.but.apply invoke } "
invoked from within
“.gid.wPostCrearResultado.but.apply instate pressed { .gid.wPostCrearResultado.but.apply state !pressed; .gid.wPostCrearResultado.but.apply instate !di…”
NL
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120713/e7bd62e6/attachment.htm
