[GiDlist] Manage Menus
Hello GiD Team.
  1. I have the problem when I want to remove the MeshQuadratic typeQuadratic menu option, for my custom problem type. I have used
    GiDMenu::RemoveOption “Mesh” [list “Quadratic type” “Quadratic”] PRE _
but it is not working. I have removed other menu options which I don’t need, but with this one it is not working.
2. What is the easiest way to put in the menu the following options:
Mesh Element type Triangular_6_Nodes(instead of Element typeTriangular with Quadratic typeQuadratic)
Mesh Element type Quadrilateral_4_Nodes (instead of Element typeQuadrilateral with Quadratic typeLinear)
Mesh Element type Quadrilateral_9_Nodes (instead of Element typeQuadrilateral with Quadratic typeQuadratic)
Note that after that I don’t need the Quadratic type option any more.
Can these Element type and Quadratic type options be merged, to have new options like I explained above? Thanks in advance for the help.
M.Marjanovic
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131016/0c0f712d/attachment.htm
I think that modify this menus is not a good idea,
In any case the ‘quadratic’ is now a global option, not a ‘local option’
that could be assigned entity by entity like the element type.
Then is not valid to allow to assign to an entity ‘Triangle 6
nodes’(quadratic) and to another entity ‘Quadrilateral 4 nodes’ (linear).
Nowadays the full mesh is quadratic or linear
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mire Marjanovic
Enviado el: miércoles, 16 de octubre de 2013 18:11
Asunto: [GiDlist] Manage Menus
Hello GiD Team.
Mesh Element type Triangular_6_Nodes (instead of Element typeTriangular
M.Marjanovic
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131016/5b2887b0/attachment.htm
