[GiDlist] (no subject)
Dear GiD team,
I am one of the GiD user. I wonder If I can post my question in your forum.
Actually, I have results from OpenSees and it is .txt format. But I wanna
see the result in GiD. I have already created the mesh in GiD and used it
in Opensees. But I do not know how I can change the txt format to GiD
format to visualize it.
Many thanks for your help!
Bahareh
Bahareh Mobasher
Ph.D. Candidate.
University of California, Irvine
The Henry Samueli School of Engineering
Civil and Environmental Engineering Department
I don’t know well OpenSees, but I think that there is some possibility to
write the results in VTK format (directly or using some additional result
converter)
Then we have implemented a plugin to be able to read this VTK files in GiD
postprocess.
If do you want, I can provide this plugin, available now for Windows x32 and
Windows x64.
(probably this plugin will be included by default in the next GiD beta
version 10.2.0b)
Sent: Thursday, January 26, 2012 3:45 AM
Dear GiD team,
forum.
Bahareh
Bahareh Mobasher
Ph.D. Candidate.
Thanks for your email. I would be happy to have that. But does it change the txt format to GiD automatically?
Bahareh
On Jan 26, 2012, at 3:00 AM, gidlist-request at listas.cimne.upc.edu wrote:
Today’s Topics:
1. (no subject) (Bahareh Mobasher)
2. Open FOAM - VTK results (Enrique Escolano)
Message: 1
Date: Wed, 25 Jan 2012 18:45:14 -0800
Message-ID:
b77c962bc4609c118fd73a47aca4cdc1.squirrel at webmail.uci.edu
Content-Type: text/plain;charset=iso-8859-1
Dear GiD team,
Bahareh
Bahareh Mobasher
Ph.D. Candidate.
Message: 2
Date: Thu, 26 Jan 2012 11:45:03 +0100
Subject: [GiDlist] Open FOAM - VTK results
Message-ID: 500A8F8E39E749C3A80AA2F4C205E8DD at mediador
Content-Type: text/plain; format=flowed; charset=“iso-8859-1”;
reply-type=original
converter)
postprocess.
Windows x64.
version 10.2.0b)
Dear GiD team,
forum.
Bahareh
Bahareh Mobasher
Ph.D. Candidate.
End of GiDlist Digest, Vol 18, Issue 5
No, our plugin allow to read VTK result files in GiD.
But as I pointed I think that it is possible for you to convert your txt
OpenFOAM files into VTK files
In the OpenFOAM distribution there is a ‘foamToVTK’ utility that you could
compile as a small executable to do this conversion from the command line
its source code is in this folder of OpenFOAM distribution (e.g.)
OpenFOAM-1.7.1\applications\utilities\postProcessing\dataConversion\foamToVTK
Sent: Thursday, January 26, 2012 6:06 PM
Subject: Re: [GiDlist] GiDlist Digest, Vol 18, Issue 5
Bahareh
Today’s Topics:
Message: 1
Message-ID:
Dear GiD team,
forum.
Bahareh
Bahareh Mobasher
Ph.D. Candidate.
Message: 2
reply-type=original
converter)
GiD
postprocess.
and
Windows x64.
version 10.2.0b)
Dear GiD team,
forum.
wanna
it
Bahareh
Bahareh Mobasher
Ph.D. Candidate.
Dear GID team,
I am trying to run an analysis where some of the elements are
progressivley “killed”. I would like to show results only for those
elements that are still “alive”, and completely remove from the
visualisation those that are “dead”. Is there a way to do this?
Many thanks,
Jose
Jose J Munoz, http://www-lacan.upc.es/munoz/
Laboratori de Càlcul Numèric (LaCàN)
Dep. Matemàtica Aplicada III
C/ Comte d’Urgell, 187, Room 1D012
Campus Urgell UPC, Edifici EUETIB
E-08036 Barcelona, Spain
j.munoz at upc.edu, Skype: josej.munoz, Tel. + 34 93 413 7253
to do this you have three options:
1- do not write results for the ‘dead elements’. When doing a c.fill,
elements with no results will not be drawn;
2- write a new mesh for each time step with the ‘dead elements’ removed;
3- write a ‘deformation’ result so that the nodes of the ‘dead elements’
fall ‘outside’ the current view, i.e. are moved far away.
Miguel Pasenau
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Jose Munoz
Enviado el: jueves, 23 de febrero de 2012 16:48
Asunto: [GiDlist] Remove dead elements from results visualisation
Dear GID team,
Many thanks,
Jose
I have two kinds of materials in my code: soil materials and concrete
materials. Is there a way to ask GiD to loop only soil materials at
one stage and loop concrete materials at another time in the .bas file
instead of having the command Loop materials which will cover all
soils and concretes? Can I use the set command to select only the soil
/ concrete materials?
Thank You,
Arash
You can do two loops, and inside take in account only the kind of material
you want
And you can have in the material a hidden field, named for example ‘class’,
to identify its category
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*if(strcmp(Matprop(class),“soil”)==0)
write its properties
*endif
*end materials
*loop materials
*if(strcmp(Matprop(class),“concrete”)==0)
*endif
*end materials
From: “Farzam-Student,STW, Arash” farzam at ostatemail.okstate.edu
Sent: Tuesday, January 31, 2012 10:05 PM
Subject: [GiDlist] Set Materials
Thank You,
Arash
Thank You very much,
I have another qustion. I have two types of elements, hexahedron and
rectangular. Can I set element type for each one and loop the nodes of
each one? I want to have all the nodes of hexahedron elements only in
one file and all the nodes of the rectangular elements only in another
file.
Best Regards,
Arash
On Wed, Feb 1, 2012 at 4:37 AM, Enrique Escolano escolano at cimne.upc.edu wrote:
you want
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
Thank You,
Arash
No, you can’t do a loop on the nodes of a type of elements with simple .bas commands.
you can do the loop on the elements of a type, and inside write all its nodes, but then you will obtain the list of nodes of this kind of element, but with repetitions.
to do this kind of special thinks you must go to Tcl scripting level. You can define a tcl procedure (inside a problemtype.tcl file it is automatically sourced) that
return what you want (the list of nodes of a type of element unrepeated)
You can invoke this Tcl procedure from the .bas file, with a *tcl(your_procedure) command, then the value returned by the procedure is directly printed in the output file.
This is an example of the procedure you need to write in your problemtype.tcl file
proc Example_GetNodesOfElementType { element_type } {
set nodes
  • foreach item [lindex [lindex [GiD_Info Mesh Elements $element_type -array] 0] 2] {
    lappend nodes {*}$item
    set nodes [lsort -integer -unique $nodes]
    return $nodes
GiD_Info Mesh is a special GiD-Tcl command (you can see the its syntax at GiD Help (GiD Customization - Tcl/Tk extension)
the rest is Tcl standard scripting language (can see documentation on Internet, and also in the help of Ramdebugger that is our Tcl/Tk editor and debugger), could open RamDebugger from the menu Data-Problemtype-Debugger…
and in the .bas file you must write something like this:
Hexahedra nodes:
*tcl(Example_GetNodesOfElementType Hexahedra)
Quadrilateral nodes:
*tcl(Example_GetNodesOfElementType Quadrilateral)
Note that I prefixed the Tcl procedure with ‘Example’, to avoid conflicts with other possible Tcl procedure that could use the same name GetNodesOfElementType
I recommend you to use a prefix or namespace related with the name of your problemtype.
Note: you can obtain multiple .dat output files, writting multiple .bas templates. a increasing number if added to the name of each .dat file (and templates are evaluated sorted alphabetically by its name)
Sent: Tuesday, February 14, 2012 12:45 AM
Subject: Re: [GiDlist] Set Materials
file.
Best Regards,
Arash
you want
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
Thank You,
Arash
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120214/3b95346f/attachment.htm
I made a .tcl file in my problem type containing:
set nodes
    -array] 0] 2] {
    return $nodes
and in my .bas file,
I have written
*NodesNum *NodesCoord
to get the nodal coordinates all hexahedra elements. It is not working
and it gives the error:
Error in base file C:/Program Files/GiD/GiD 9.0.2/problemtypes/FLODEF
V11.gid/FLODEF V11-post.bas at line number 3: Error in TCL expression:
‘invalid command name “Example_GetNodesOfElement_Type”’
I would be happy to have your comment.
Thank You,
Arash Farzam
On Tue, Feb 14, 2012 at 4:22 AM, Enrique Escolano
commands.
set nodes
  • __ foreach item [lindex [lindex [GiD_Info Mesh Elements $element_type
    -array] 0] 2] {
    return $nodes
    Hexahedra nodes:
    problemtype.
file.
Best Regards,
Arash
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
Thank You,
Arash
In order to be automatically sourced by GiD, the name of the tcl file must
be "FLODEF V11.tcl "
(the same as the problemtype and .tcl extension)
Sent: Monday, February 20, 2012 7:08 PM
set nodes
    -array] 0] 2] {
    return $nodes
I have written
Thank You,
Arash Farzam
.bas
commands.
set nodes
    -array] 0] 2] {
    return $nodes
    and
    Hexahedra nodes:
    problemtype.
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
Thank You,
Arash
Yes, actually I have named it the same. I just wrote problem type in
the email for avoiding confusion. But still, I get the same error.
Arash
On Mon, Feb 20, 2012 at 12:35 PM, Enrique Escolano
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    set nodes
      -array] 0] 2] {
      return $nodes
      and
      Hexahedra nodes:
      problemtype.
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
Thank You,
Arash
I attach a simple problemtype that works well
Sent: Monday, February 20, 2012 7:58 PM
Arash
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    set nodes
      -array] 0] 2] {
      return $nodes
      and
      Hexahedra nodes:
      your
      problemtype.
(and
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
Thank You,
Arash
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120221/05c97cfd/attachment.obj
I use the exact same problem type that you emailed me, but still, I
get the error:
V11.gid/FLODEF V11-z.bas at line number 2: Error in TCL expression:
‘info Mesh Elements Elemtype ?first? ?last? ?-sublist? with
first,last0’
Do you know what the reason might be for this error?
Thank You,
Arash
On Tue, Feb 21, 2012 at 5:06 AM, Enrique Escolano
----- Original Message ----- From: “Farzam-Student,STW, Arash”
Arash
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    set nodes
      -array] 0] 2] {
      return $nodes
      and
      Hexahedra nodes:
      your
      problemtype.
(and
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
Thank You,
Arash
The problem is that your GiD version 9.0.2 is old, and the command GiD_Info
Mesh of this versions don’t support the syntax -array I’ve used.
Download the last GiD developer version 10.2.1.d from our web
http://www.gidhome.com/download/developer-versions
Sent: Monday, February 27, 2012 11:12 PM
get the error:
'info Mesh Elements Elemtype ?first? ?last? ?-sublist? with
first,last0’
Thank You,
Arash
Arash
must
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    You
    unrepeated)
    is
    set nodes
      -array] 0] 2] {
      return $nodes
      at
      and
      Hexahedra nodes:
      conflicts
      your
      problemtype.
(and
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
file
soil
Thank You,
Arash
Will I be able to use the version 10.2.1.d with my same software key?
On Tue, Feb 28, 2012 at 3:47 AM, Enrique Escolano
_http://www.gidhome.com/download/developer-versions_
get the error:
first,last0’
Thank You,
Arash
Arash
must
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    You
    unrepeated)
    is
    set nodes
      -array] 0] 2] {
      return $nodes
      at
      and
      Hexahedra nodes:
      conflicts
      your
      problemtype.
(and
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
file
soil
Thank You,
Arash
The password for version 10 is valid for all the 10.x.x versions, but the
password change between main versions (from 9 to 10, for example).
ABEL
Enviado el: miércoles, 29 de febrero de 2012 21:55
Asunto: Re: [GiDlist] Set Materials
On Tue, Feb 28, 2012 at 3:47 AM, Enrique Escolano escolano at cimne.upc.edu
GiD_Info Mesh of this versions don’t support the syntax -array I’ve used.
get the error:
first,last0’
Thank You,
Arash
Arash
file must be "FLODEF V11.tcl "
proc Example_GetNodesOfElementType { element_type } { set nodes
__
    $element_type -array] 0] 2] { lappend nodes {*}$item } set nodes
    [lsort -integer -unique $nodes] return $nodes }
    I have written
    *tcl(Example_GetNodesOfElementType Hexahedra) *NodesNum *NodesCoord
    working and it gives the error:
    9.0.2/problemtypes/FLODEF V11.gid/FLODEF V11-post.bas at line number 3:
    Thank You,
    Arash Farzam
    You
    automatically sourced) that return what you want (the list of
    unrepeated)
    __
      syntax at GiD Help (GiD Customization - Tcl/Tk extension) the rest
      Hexahedra nodes:
      *tcl(Example_GetNodesOfElementType Hexahedra) Quadrilateral nodes:
      same name GetNodesOfElementType I recommend you to use a prefix or
its name)
and rectangular. Can I set element type for each one and loop the
nodes of each one? I want to have all the nodes of hexahedron
elements only in one file and all the nodes of the rectangular
elements only in another file.
Best Regards,
Arash
material you want And you can have in the material a hidden
field, named for example ‘class’, to identify its category
MATERIAL:xxx Question:class Value:soil State:hidden …
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
concrete materials. Is there a way to ask GiD to loop only soil
materials at one stage and loop concrete materials at another
time in the .bas file instead of having the command Loop
materials which will cover all soils and concretes? Can I use
the set command to select only the soil / concrete materials?
Thank You,
Arash
No, the password of versions 10.x is different of the passwords of version 9.x. Could try GiD 10.x with a trial one month password
You can restrict the use of GiD-Tcl commands to the ones available on GiD 9.0.2 (see Help-Customization-TclTk extension)
in this version you can’t use the -array flag of the command
but for example could use
GiD_Info Mesh Elements $element_type -sublist
this is the procedure modified to work also with your version:
set nodes
  • foreach item [GiD_Info Mesh Elements $element_type -sublist] {
    lappend nodes {*}[lrange $item 1 end-1]
    return $nodes
Sent: Wednesday, February 29, 2012 9:55 PM
get the error:
first,last0’
Thank You,
Arash
Arash
must
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    You
    unrepeated)
    is
    set nodes
      -array] 0] 2] {
      return $nodes
      at
      and
      Hexahedra nodes:
      conflicts
      your
      problemtype.
(and
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
file
soil
Thank You,
Arash
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120301/ebc81597/attachment-0001.htm
Thank You for the update,
Is this new code (with the sublist being used instead of array) still
supposed to write the nodes? I tried it and it gave me just one single
number instead of the list of the nodes.
Thank You
On Thu, Mar 1, 2012 at 4:02 AM, Enrique Escolano escolano at cimne.upc.edu wrote:
Password Alert! This message may contain a request for your password. NEVER
SEND OR RESPOND TO E-MAIL REQUESTS FOR YOUR PASSWORD. For questions about
this alert, please contact the IT HelpDesk at 405-744-4357 or email
helpdesk at okstate.edu.
set nodes
  • __ foreach item [GiD_Info Mesh Elements $element_type -sublist] {
    return $nodes
GiD_Info
get the error:
first,last0’
Thank You,
Arash
Arash
must
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    simple
    .bas
    commands.
    its
    element,
    You
    unrepeated)
    procedure
    is
    set nodes
      -array] 0] 2] {
      return $nodes
      syntax
      at
      editor
      and
      Hexahedra nodes:
      conflicts
      your
      problemtype.
.bas
(and
of
another
file.
Best Regards,
Arash
material
you want
‘class’,
MATERIAL:xxx
Question:class
Value:soil
State:hidden
END MATERIAL
*loop materials
*endif
*end materials
*loop materials
*endif
*end materials
concrete
file
soil
Thank You,
Arash
