[GiDlist] Post process tools/background image
Hi, GiD team.
I have two questions.
The first one shoul be sent to
the “wishlist” instead of the gidlist. We are using the tool for
integrating the results over a mesh. It is very useful for us. However, we
miss the posibility of using one surface set or isosurface to cut another
mesh. It would be essential for us. Right now, we have to separate the
elements below the free surface from the ones above via do cutside by
selection, but this way we miss precision, because of the elements which
are partly above and partly below.
The second question is about
preprocess. I set a background image; it works ok. But if I save the case
and then reopen it, the image disappears. How can I keep it?
Fernando Salazar González
Director de CIMNE-Madrid
Paseo Gral Martínez Campos, 41. 28010 Madrid.
Tel. +34 913 191 359
Móvil. +34 610 234 477
fsalazar at cimne.upc.edu [1]
www.cimne.com [2]
AVISO IMPORTANTE
Los datos de carácter personal
contenidos en el mensaje, se registrarán enun fichero para facilitar la
gestión de las comunicaciones de CIMNE. Se pueden ejercitar los derechos de
acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a
nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte
UPC, 08034 Barcelona, España.
AVIS IMPORTANT
Les dades de caràcter
personal contingudes en aquest missatge es registraran en un fitxer per
facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els
drets d’accés, rectificació, cancel·lació i oposició, per escrit a les
nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC,
08034 Barcelona, Espanya.
IMPORTANT NOTICE
All personal data contained
in this mail will be processed confidentially andstored in a file property
of CIMNE in order to manage corporate communications. You may exercise the
right of access, rectification, deletion and objection by letter sent to
CIMNE, Gran Capitán, Edificio C1 - Campus Norte UPC, 08034 Barcelona,
Spain.
Links:
[1] mailto:fsalazar at cimne.upc.edu
[2]
http://www.cimne.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100714/1b1eee02/attachment.htm
You can’t keep the background image.
we must implement that this information is saved/restored in the model database (we will do it for next betas)
Sent: Wednesday, July 14, 2010 12:52 PM
Subject: [GiDlist] Post process tools/background image
Hi, GiD team.
The first one shoul be sent to the “wishlist” instead of the gidlist. We are using the tool for integrating the results over a mesh. It is very useful for us. However, we miss the posibility of using one surface set or isosurface to cut another mesh. It would be essential for us. Right now, we have to separate the elements below the free surface from the ones above via do cutside by selection, but this way we miss precision, because of the elements which are partly above and partly below.
The second question is about preprocess. I set a background image; it works ok. But if I save the case and then reopen it, the image disappears. How can I keep it?
Fernando Salazar González Ingeniero de Caminos, Canales y Puertos Director de CIMNE-Madrid Paseo Gral Martínez Campos, 41. 28010 Madrid. Tel. +34 913 191 359Móvil. +34 610 234 477 fsalazar at cimne.upc.edu www.cimne.com AVISO IMPORTANTE Los datos de carácter personal contenidos en el mensaje, se registrarán enun fichero para facilitar la gestión de las comunicaciones de CIMNE. Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España. AVIS IMPORTANT Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya. IMPORTANT NOTICE All personal data contained in this mail will be processed confidentially andstored in a file property of CIMNE in order to manage corporate communications. You may exercise the right of access, rectification, deletion and objection by letter sent to CIMNE, Gran Capitán, Edificio C1 - Campus Norte UPC, 08034 Barcelona, Spain.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100714/2fbd8ac3/attachment.htm
