[GiDlist] Postproceso
¿Es posible ver los resultados (Contour Fill) en simultáneo para elementos
distintos? ¿Por ejemplo triángulo y cuadrángulo?
No consigo realizarlo ni usando “Several Results”.
Gracias.
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML…
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120716/f0e9e7f8/attachment.htm
En la última version developer 11.1.0d ya esta corregido el problema con ‘several results’
http://www.gidhome.com/download/developer-versions
Descarga esta versión y vuelve a probarlo superponiendo ambos resultados desde la ventana ‘several results’
Sent: Monday, July 16, 2012 10:59 PM
Subject: [GiDlist] Postproceso
¿Es posible ver los resultados (Contour Fill) en simultáneo para elementos distintos? ¿Por ejemplo triángulo y cuadrángulo?
Gracias.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120717/e3963efe/attachment.htm
Hi GiD listers
I have started to use Comsol recently and wondered if anyone is using GiD to produce meshes for comsol analysis and if so would they like to share their procedure in exporting a comsol compatible mesh file? I don’t suppose anyone knows if there exists a comsol problem type anywhere?
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120723/c17e133d/attachment.htm
Hello Mark,
We don’t know the existence of any problemtype GiD-Comsol,
I had a look to its web and it seems that is could import meshes in Nastran format, then you can export the GiD mesh in this format
to do it do you have two options:
1- Files-Export-Using template-NastranMesh
then the mesh is written with a simple template.
2- Download the GiD-Nastran 4.1 problemtype (from the menu Data-Problemtype-Internet retrieve…)
load it and then you can apply Nastran conditions and materials that will be written in the calculation file in Nastran format with
Files-Export-Calculation file, or pressing Calculate-Calculate
but I don’t know if Comsol is able to read from Nastran other data apart of the mesh
Sent: Monday, July 23, 2012 7:52 PM
Subject: [GiDlist] Producing meshes for Comsol
Hi GiD listers
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120725/8f24b634/attachment.htm
En la versión 11.1.0d directamente no me funciona “Several Results” (no me
abre ninguna ventana). La utilizo como versión de prueba.
Gracias.
On Wed, Jul 18, 2012 at 7:00 AM, gidlist-request en listas.cimne.upc.eduwrote:
gidlist en listas.cimne.upc.edu
gidlist-owner en listas.cimne.upc.edu
Today’s Topics:
1. Re: Postproceso (Enrique Escolano)
Message: 1
Date: Tue, 17 Jul 2012 15:40:44 +0200
Subject: Re: [GiDlist] Postproceso
To: gidlist en listas.cimne.upc.edu
Message-ID: EC226082339A4E34A51EA30CC33E22A3 en mediador
Content-Type: text/plain; charset=“iso-8859-1”
En la ?ltima version developer 11.1.0d ya esta corregido el problema con
‘several results’
_http://www.gidhome.com/download/developer-versions_
Descarga esta versi?n y vuelve a probarlo superponiendo ambos resultados
?Es posible ver los resultados (Contour Fill) en simult?neo para
elementos distintos? ?Por ejemplo tri?ngulo y cuadr?ngulo?
Gracias.
GiDlist en listas.cimne.upc.edu
URL:
_http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120717/e3963efe/attachment.html_
End of GiDlist Digest, Vol 24, Issue 6
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120730/2cad3719/attachment.htm
Hola,
¿Qué versión has descargado (sistema operativo)?
¿Aparece algún error?
Gracias,
(no me abre ninguna ventana). La utilizo como versión de prueba.
Gracias.
On Wed, Jul 18, 2012 at 7:00 AM, gidlist-request at listas.cimne.upc.edu
gidlist at listas.cimne.upc.edu mailto:gidlist at listas.cimne.upc.edu
mailto:gidlist-owner at listas.cimne.upc.edu
Today’s Topics:
Message: 1
mailto:escolano at cimne.upc.edu
Message-ID: EC226082339A4E34A51EA30CC33E22A3 at mediador
Gracias.
GiDlist at listas.cimne.upc.edu mailto:GiDlist at listas.cimne.upc.edu
URL:
Anna Monros Bellart
AVISO IMPORTANTE
AVÍS IMPORTANT
del CIMNE. Es poden exercir els drets d’accés, rectificació,
cancel•lació i oposició, per escrit a les nostres oficines del CIMNE,
IMPORTANT NOTICE
Yo he probado con la version 11.1.0d win x32 y si que se me abre la ventana ‘several results’
¿que version de GiD usas? (Linux, windows, x32 o x64)
quizá tambien puede que afecte en algo lo que contiene tu fichero de resultados.
Envianos un zip con el ejemplo si es pequeño para probar con tu mismo caso. (puedes enviarlo directamente a escolano at cimne.upc.edu en vez de la gid list)
Sent: Monday, July 30, 2012 7:42 PM
Subject: Re: [GiDlist] GiDlist Digest, Vol 24, Issue 6
En la versión 11.1.0d directamente no me funciona “Several Results” (no me abre ninguna ventana). La utilizo como versión de prueba.
Gracias.
On Wed, Jul 18, 2012 at 7:00 AM, gidlist-request at listas.cimne.upc.edu wrote:
Today’s Topics:
Message: 1
En la ?ltima version developer 11.1.0d ya esta corregido el problema con ‘several results’
Descarga esta versi?n y vuelve a probarlo superponiendo ambos resultados desde la ventana ‘several results’
?Es posible ver los resultados (Contour Fill) en simult?neo para elementos distintos? ?Por ejemplo tri?ngulo y cuadr?ngulo?
Gracias.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120717/e3963efe/attachment.html
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120731/404f48fa/attachment-0001.htm
Bonjour,
Je suis absent jusqu’au lundi 13 août. Vos emails ne seront pas lus.
En cas d’urgence, adressez votre message ici : info at mp-ingenieurs.ch
Eric Tonicello
Hi !
I’m out of office and I’ll be back on MondayJuly 3.
My emails won’t be read during this period.
In case of urgent matter, please send your message here : info at mp-ingenieurs.ch
Eric Tonicello
