Thank you very much Enrique. It works well now.
Giang
Sent: Tuesday, July 13, 2004 2:05 PM
Subject: Re: [GiDlist] postprocess - problem reading file
It exists another problem in your file:
The mesh name defined inside your .msh file is “4-point shear test 2”
GiD Post Results File 1.0
MESH “4-point shear test 2” dimension 2 ElemType Triangle Nnode 6
But your 3pG gauss points are defined for a mesh named “4pshear2”
GaussPoints “3pG” ElemType Triangle “4pshear2”
Must use the same mesh name, “4-point shear test 2” or “4pshear2”, inside this two files
Note: for the mesh file avoid the header line GiD Post Results File 1.0, it’s only for the results file.
Sent: Sunday, July 11, 2004 1:47 PM
Thanks a lot Enrique. The values of quantities at Gauss points can be read now. However, somehow they cannot be plotted out, although the max and min values appear correctly in the box above the command line. I have tried with nodal quantities and it is OK, but still could not plot out anything at Gauss points. Would you and any others here mind having a look at the problem again? Thank you very much in advance.
Giang
Sent: Friday, July 09, 2004 5:35 PM
To avoid this error message, must end with a carriage return your last result file line: “End Values”
Sent: Friday, July 09, 2004 12:07 PM
Subject: [GiDlist] postprocess - problem reading file
Dear all,
Would any one here please let me know what happens with my data files (attached herewith), as the following error message always appears every time I open the files, although I have all the required section for a post-process in my .res file?
No ‘Values’ section found before the EOF
in line 12 of file ‘f:/my documents/gid data/4pshear2.res’.
Thank you in advance.
Giang
P.S.
I’m new to GiD and using the academic version at the moment.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040713/e014cd9a/attachment.htm
