there was a bug in gid when the names of the groups has spaces. This has
been solved. Until we make public the next version, you can try not using
spaces in the group’s name.
Another advice is that all the results of one mesh group should be specified
inside a single ‘Ongroup–end ongroup’ block.
In your example your have declared several ‘Ongroup–end ongroup’ blocks:
onGroup “step 0”
Result “unoda0” “Load Analysis” 0 Scalar OnNodes
end ongroup
onGroup “step 0”
Result “unodb0” “Load Analysis” 0 Vector OnNodes
end ongroup
onGroup “step 1”
the correct way is:
onGroup “step 0”
end ongroup
onGroup “step 1”
I send you enclosed your example patched.
best regards,
Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de CHEN Ningning
Enviado el: viernes, 15 de enero de 2010 14:01
Asunto: [GiDlist] PostProcess problem
My question is:
I want to plot two field result in one .flavia.res file.
if the mesh is fixed in every time step, it works well.
But when the mesh is changed with time step( I mean I use the group and on
group, see in attachment), although two field result is read in, the
postprocess only show one field.
Is it some problem with the .res file?
The attachment is post-process mesh and result file.
xjtucnn at 163.com
2010-01-15
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100125/ca190e44/attachment.obj
