Dear Kim,
first of all, you should divide your volume in 6-sided volues, to be able to
mesh all of them with structured quadrilateral. A cube with a shpere hole
inside cannot be meshed as structured.
Then, if you want to concentrate elements in the sphere, you can select the
option ‘Mesh-Structured-Lines-Concentrate elements’, which allows you to
apply concentration weights to the end nodes of a line, leading to a
concentration of elements where you want.
Kind regards,
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per
IMPORTANT NOTICE
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Seungil Kim
Enviado el: miércoles, 17 de noviembre de 2010 6:32
Asunto: [GiDlist] quadrilateral mesh on a cubic domain with a ball hole
Hi, all
I would like a structured quadrilater mesh in a cubic domain
with a ball removed.
For exmaple Domain = [-2,2]X[-2,2]X[-2,2]\a ball radius of 0.1
But a problem is that the mesh I would like to generate
is finer around the sphere of radius 1 than the other part of the domain.
Could you let me know how to generate the mesh?
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101117/7db14c8d/attachment.htm
