I think that I have a simple problem, but since was released that last version of the program that I can’t to print the results on the truss elements. I attached a simple example with 5 bars to illustrate (post-processor files). I would like to see the results directly on the bars.
-Luís.
====================================================== Luís A. G. Bitencourt Jr., Doctoral Student
Polytechnic School at the University of São Paulo - Brazil
WebPage: http://www.lmc.ep.usp.br/people/lbitencourtjr/
Research Page: http://www.lmc.ep.usp.br/people/tbitten/gmec/home.htm
Phone: +55 11 3091 5677
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130328/73d31748/attachment.htm
Type: application/zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130328/73d31748/attachment.zip
Your result file is ok
I think that the problem is not the GiD version, and probably you don’t have the latest version (released the past week): 11.0.4 is the last official and 11.1.3d is the last developerr version
Probably do you have some user preferences that not show the bars properly.
Check for example Options-Geometry-Line options…
and Window-View style… (maybe your set is off)
Can see for example bar strains with
View Results-Contour fill-Strains
or
View Results-Line diagram-Scalar-Strains
If you are unable to see these results try to reset your postproces user preferences deleting the files .GiDPostPreferences.ini and gid.ini, located at
Windows XP: C:\Documents and Settings\current user\Application Data\GiD
Windows Vista , 7, 8: C:\Users\current user\AppData\Roaming\GiD
Linux / Mac OS X: $(HOME)
Sent: Thursday, March 28, 2013 9:33 PM
Subject: [GiDlist] Question
-Luís.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130402/f346ec7a/attachment.htm
