I’m working on a problem where I’m animating a very large number of
solution steps during which the observer also moves depending on the
solution. I got this working by writing a batch file, but due to the large
domain and movement of the observer, I probably have to apply an
additional smoothing routine because the observers movement & solution
in general cause the animation to appear a bit “unstable” (i.e. it
oscillates to some extent). Since I
would
rather not act on the actual raw data I’m animating, what would be the
simplest way of doing over the timestep data smoothing ?
Appreciate any ideas,
Anssi Laukkanen
I have a question of more general nature regarding GiD’s mesh generation of three dimensional objects. My impression is that initially, a surface mesh is created from which the volume mesh is built. If this is the case, what are the requirements/properties of the surface mesh (e.g. Delaunay)?
Thanks in advance!
India.com free e-mail - www.india.com.
Check out our value-added Premium features, such as an extra 20MB for mail storage, POP3, e-mail forwarding, and ads-free mailboxes!
Powered by Outblaze
Yes, before generate in GiD a volume mesh, are generated the boundary
elemens.
The used method is an advancing front, is not a delaunay alghoritm.
The nodes and elements are generated with some good shape and size
requierements
Sent: Friday, April 02, 2004 7:45 PM
Subject: [GiDlist] general question on GiD’s mesh generation…
Thanks in advance!
Powered by Outblaze
