[GiDlist] {SPAM?} Question about Material definition
Can anybody tell me what is wrong with this material definition?
The problem seems to be the ‘Z’ option for the ‘Direction’ question. If I
try to modify the value of ‘Direction’ to ‘Z’ through the ‘Materials’
dialog in GiD, the material does not get modified successfully. Moreover,
if the default value is ‘Z’, I cannot even create a new material from ‘Source’.
However, if the ‘Z’ is removed from the material definition, ( i.e.
QUESTION: Direction:#CB#(X,Y) ), everything works fine!
NUMBER: 1 MATERIAL: Source
QUESTION: Duration_of_pulse
VALUE: 2e-8
QUESTION: Pulse_Offset
VALUE: 6e-8
QUESTION: Center_Frequency_of_Pulse
VALUE: 1
QUESTION: Source_Voltage
VALUE: 1
QUESTION: Source_Resistance
VALUE: 1
QUESTION: Direction:#CB#(X,Y,Z)
VALUE: X
END MATERIAL
Rama Karve
