Dear Zhao,
I think the problem may be that you are not assigning the number of cells to
the lines of the surface:
when you select Mesh-Structured Surfaces-Assign number of cells (or Assign
Sizes), you select the surfaces, and then a window appears asking for the
number of cells (or size) to be assigned to the lines of that surfaces. If
you assign the number of cells to the lines (by entering the number,
clicking on ok and selecting the lines), it should work like you expect. If
you close that window without assigning any size, the size assigned to that
lines when generating the mesh will be the general mesh size assigned to the
model (the one entered in the window that appears after selecting
Mesh-Generate Mesh).
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per
IMPORTANT NOTICE
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de ???
Enviado el: sábado, 08 de enero de 2011 7:57
Asunto: [GiDlist] TCL GiD_Process Mesh structured Lines
Dear GIDlist
My computer is a laptop.When we use GID in Windows XP, there is much
problem with the display of the operation, for example, if we use
Mesh/structured/Lines/concentrate elements and
Mesh/structured/surfaces/Assign,the results of unit number is 2 and the
number of nodes is 6, but when we use GID in Desktop computer in the same
method ,the results of unit number is 100 and the number of nodes is 153
,the result is is an ideal.In addtion,Card name of my laptop is NVIDIA
GeForce G105m.
Does somebody also meet this problem, and we look forward to your
solution!
Kind regards,
Xiao-long Zhao
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110111/edcc3fc8/attachment.htm
