Hello GiD team,
I have been stuck of this problem for a while I need to sort it out soon.
Any suggestion/help is greatly appreciated.
I have two or more analysis. For e.g. first there is a large deformation of
the body and then there is a thermal shrinkage/expansion on the same body
after the large deformation. So I write out two .post.res file with two sets
of displacements and other results. So, the meshes for these two files are
different.
.post.msh] and [-1.post.res - *-1.post.msh] then there is an error when I
try to load the files using a *.post.lst file. Is this a bug?
*post.res file but I don’t think I can define define multiple mesh groups in
a single *.post.msh. I get errors again. I get errors about Gauss points not
being defined even though it is defined.
Basically what I want is - I have two or more sets of results which use
different meshes. I can write out the meshes in any form/file from my
solver. How do I use different meshes of different results in postprocess
for displacements etc.?
Please let me know if I should send a sample project file which might be
helpful to find out what’s wrong.
Thanks a lot,
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101006/d2bb6f85/attachment.htm
Send us a small example of each problem you are having, to say if there is some error on the files syntax, or an error or missing feature to fix in Gid.
And maybe the problemtype could be necessary, or at least to know what is necessary to repeat your process (like set PropertyToPost Material or other kind of tricks)
Note: for big or confidential examples, send it directly to me at escolano at cimne.upc.edu
Sent: Wednesday, October 06, 2010 9:23 PM
Subject: [GiDlist] Using Different Meshes
Hello GiD team,
I have been stuck of this problem for a while I need to sort it out soon. Any suggestion/help is greatly appreciated.
I have two or more analysis. For e.g. first there is a large deformation of the body and then there is a thermal shrinkage/expansion on the same body after the large deformation. So I write out two .post.res file with two sets of displacements and other results. So, the meshes for these two files are different.
Basically what I want is - I have two or more sets of results which use different meshes. I can write out the meshes in any form/file from my solver. How do I use different meshes of different results in postprocess for displacements etc.?
Please let me know if I should send a sample project file which might be helpful to find out what’s wrong.
Thanks a lot,
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101014/81cba916/attachment.htm
- With groups now must use a single .msh file, about the problem to use a .lst file send us the whole example.
- In theory it is possible to use a single .res and a single .msh with groups, send us the example.
Hello GiD team,
Thanks a lot,
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101014/e1bf9e8e/attachment.htm
