[GiDlist] Visualization of Mesh in Post processing
Dear everybody,
Each time, when I change Gid from Pre to postprocess (click to button: "Toggle between pre and postprocess), I always see at first as seen in Post1.gif and I can’t see the mesh.
Can you show me how I can see the mesh (as seen in Post2.gif) after click to this button.
Thank you in advance.
M N Vu
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110826/c9213d90/attachment-0001.htm
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110826/c9213d90/attachment-0002.gif
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110826/c9213d90/attachment-0003.gif
You can change between several display styles through the “Select &
Display Style” window (Utilities-View Style). In order to see the mesh
please select “All lines” or “Body Lines” in the Style menu (in the left
bottom side of the window).
You can also use the “Display Style” button placed in the “Geometry &
View bar”
El 26/08/2011 15:40, V M Ngoc escribió:
Dear everybody,
M N Vu
Anna Monros Bellart
AVISO IMPORTANTE
AVÍS IMPORTANT
del CIMNE. Es poden exercir els drets d’accés, rectificació,
cancel.lació i oposició, per escrit a les nostres oficines del CIMNE,
IMPORTANT NOTICE
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110829/ec9eff1e/attachment.htm
Maybe do you have set some unwanted user preference, you can reset this preferences deleting the files
.GiDPostPreferences.ini and gid.ini, located in Windows Vista/7 in the folder
C:\Users\your_user\AppData\Roaming\GiD
(your_user depends of your own user)
if you delete this files they will be rebuilt with default values when starting GiD
Sent: Monday, August 29, 2011 10:54 AM
Subject: Re: [GiDlist] Visualization of Mesh in Post processing
You can change between several display styles through the “Select & Display Style” window (Utilities-View Style). In order to see the mesh please select “All lines” or “Body Lines” in the Style menu (in the left bottom side of the window).
You can also use the “Display Style” button placed in the “Geometry & View bar”
Dear everybody,
M N Vu
Anna Monros Bellart
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán en un fichero para facilitar la gestión de las comunicaciones de CIMNE. Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVÍS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d’accés, rectificació, cancel.lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110831/5846e532/attachment.htm
