The normal way to use this problemtype is create or import the geometry in GiD, apply conditions and loads and then export all data in a .s2k file to be calculated by SAP2000, not the inverse.
As you pointed the current SAP2000 problemtype is only importing the mesh information of the .s2k file
tried using Konstru and CSi X Revit but we find that that the model is never precise enough for drawing production and you end up adjusting/fixing everything in Revit anyways.
Have you exported the .s2k file with this SAM2000 interface?
You can increase the default precision of real numbers printed as text adding to the start of the file
\problemtypes\SAP2000.gid\SAP2000.bas
this command:
*realformat “%15.5f”
(the format has C syntax)
No you can not import .s2k file in SAP 2000 because their are two options of creating and opens your back FM Whatsappfiles and exporting your projecting including your geometry constructional and structural diagrams to the .s2k files.
I didn’t understood well your comment.
Modern SAP2000 versions don’t have the option to import any .s2k file?
or it is failing importing some specific case written by the GiD-SAP2000 interface?
