Hi
I built a model in GID and I want to select one or more nodes, but when I click on the right option, the first option (contextual) is disabled and I do not enable this option so I can choose nodes. Maybe it’s possible Can you guide me so how can I active this option (contextual) until select nodes?
thanks in advance.
The selection of nodes is enabled only when a function is requiring to select this type of entity,
e.g.
if do you use a tool like
Utilities->List->nodes
then you can select the nodes,
but when the function has finished you cannot select them.
