Moment load to a 3D model
Hello everyone,
How can I apply a moment load at a surface? Ideally, I would like to apply it at a point and then connect the point to the surface, but I don´t know how this can be done.
(I have also applied at the surface an horizontal load by converting it to kPa, but if there is a better way of applying it (like using a point), I would prefer it.)
Thank you in advance
Can force a inner point on a surface (with a tolerance) to be a node of the surface mesh with
Mesh->Mesh criteria->Force points to->Surface mesh
