No subject
  1. Support for spheres (defined by a centre node and a radius) and circles
    (defined by a centre node, a radius and a normal) in Postprocess. Spheres
    can be cut and create in circles. If the normal for the circles are not
    given GiD assumes the normal ( 0.0, 0.0, 1.0).
  2. Stream ribbons as stream lines with detail level=2 with rotational.
  3. Detail level point for stream lines showing the calculated points from
    the stream.
  4. Contour Fill colours with shininess
  5. New Display Style mode for meshes: ‘Points Bound’ showing the nodes as
    spheres and the boundary lines of the mesh.
  6. Isosurfaces can be seen although all the meshes are switched off.
  7. Support for BMP files with 32bpp.
  8. Join surfaces function.
