No subject
  1. New quadrilateral mesher
  2. Boundary regular transition meshing preference
  3. NURBS simplification operators: knot removal and degree reduction for
    curves and surfaces
  4. Preview image saved with the model, to be show in the Open project window
  5. Can read TIFF files for background images and textures
  6. Stream lines implemented for hexahedra, prisms, pyramids and
    quadrilaterals
  7. Supported hexahedra of 20 nodes in postprocess
  8. Macro to create a vector result from an scalar result
  9. Smoothing of triangles and quadrilaterals: new opcion LaplaceSmooth to
    only apply a laplacian smooth, with angle tolerance and try to save the
    enclosed volume
  10. Math functiones like max, min, log, log10 can be used in template bas
    files, *nintervals command
  11. Delaunay volume mesher (GiD_Set VolumeMesher 1)
  12. Command line parameter -c2 yourfile.ini, to specify in a problemtype
    to use “yourfile.ini” instead “gid.ini”, to avoid sharing the configuration
  13. GidUtils::DisableToolbar tool and GidUtils::EnableToolbar tool, to
    prevent show some tools, like the “Right buttons”
Miguel Pasenau
