No subject
Note: your GiD7.2 password remain valid for all 7.x versions
=20
To: gidlist at gatxan.cimne.upc.es=20
Cc: miguel at cimne.upc.es=20
Sent: Thursday, November 27, 2003 10:01 PM
Subject: [GiDlist] Loading of RES file
Hi!
=20
I have been using GiD as a pre- and post-processor tool for my Finite =
Element code since 2001. I have been a very happy and enthusiastic user =
of GiD up to now. Last week I was trying to change the format of my =
output files in order to improve the efficiency of my GiD postprocessing =
stage. I decided to group some nodal results with the keyword =
“ResultGroup”, instead of the “Result” keyword I have been using so far. =
Following the instructions at GiD manual, the appropriate changes in the =
file structure were made. However, when loading the new “.res” file in =
the GiD postprocessor, a Windows error message pops up in the screen, =
and says “The exception unknown software exception (0xc00000fd) occurred =
in the application at location 0x007e54d7”. Upon clicking in the =
“cancel” button a Visual Fortran Debugger is automatically initiated and =
prompts “unhandled exception in gid.exe: 0xC00000DF: stack overflow”. I =
looked for errors in my “.res” file but I could not find any. Then I =
decided to run the example from “HelpPostprocess data filesNew =
postprocess results formatresults example” and I found that the same =
error occurs when loading the “.res” file. Is there any tricky thing in =
using the keyword “ResultGroup”??? (I am using the 7.2 version of GiD) =
Attached to this email you can find the mesh file and the result file =
that I have been trying to use (these are the examples from GiD manual). =
I appreciate very much your kind attention, and wait for your reply as =
soon as possible.
=20
Gracias!
Eduardo Campello
Department of Structural and Foundation Engineering
University of S=E3o Paulo, S=E3o Paulo - Brazil
Phone/Fax: 55 11 3091-5367 and 11 55 3091-5181
------=_NextPart_000_0083_01C3B535.C1C679D0
Content-Type: text/html;
charset=“iso-8859-1”
!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.0 Transitional//EN”
HTML xmlns:o =3D “urn:schemas-microsoft-com:office:office"HEAD
charset=3Diso-8859-1”
META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR
STYLE/STYLE
/HEAD
BODY bgColor=3D#ffffff
DIVFONT face=3DArial size=3D2This is corrected =
bug./FONT/DIV
DIVFONT face=3DArial size=3D2Update the the last available beta =
version: at this=20
moment 7.4.4b for Windows and Linux/FONT/DIV
DIVFONT face=3DArial size=3D2From the beta versions section: =
/FONTFONT=20
face=3DArial size=3D2A=20
href=3D"http://www.gidhome.com/download/do07.subst"http://www.gidhome.co=
m/download/do07.subst/A/FONT/DIV
DIVFONT face=3DArial size=3D2/FONT /DIV
DIVFONT face=3DArial size=3D2Note: your GiD7.2 password remain=20
valid for all 7.x versions/FONT/DIV
DIVFONT face=3DArial size=3D2 /FONTFONT face=3DArial =
size=3D2/FONT/DIV
DIVFONT face=3DArial size=3D2Regards/FONT/DIV
DIVFONT face=3DArial size=3D2Enrique Escolano/FONT/DIV
BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"
DIV style=3D"FONT: 10pt arial"----- Original Message ----- /DIV
DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"BFrom:/B=20
A title=3Dcampello at usp.br href=3D"mailto:campello at usp.br"Eduardo =
Campello/A=20
/DIV
title=3Dgidlist at gatxan.cimne.upc.es=20
href=3D"mailto:gidlist at gatxan.cimne.upc.es"gidlist at gatxan.cimne.upc.es/=
A=20
/DIV
DIV style=3D"FONT: 10pt arial"BCc:/B A =
title=3Dmiguel at cimne.upc.es=20
href=3D"mailto:miguel at cimne.upc.es"miguel at cimne.upc.es/A /DIV
DIV style=3D"FONT: 10pt arial"BSent:/B Thursday, November 27, =
2003 10:01=20
PM/DIV
DIV style=3D"FONT: 10pt arial"BSubject:/B [GiDlist] Loading of =
RES=20
file/DIV
DIVBR/DIV
P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"SPAN lang=3DEN-US=20
style=3D"mso-ansi-language: EN-US"FONT size=3D3FONT=20
face=3D"Times New Roman"Hi!o:p/o:p/FONT/FONT/SPAN/P
face=3D"Times New Roman" o:p/o:p/FONT/FONT/SPAN/P
style=3D"mso-ansi-language: EN-US"FONT size=3D3FONT face=3D"Times =
New Roman"I=20
Element=20
code since 2001. I have been a very happy and enthusiastic user of GiD =
up to=20
now. Last week I was trying to change the format of my output files in =
order=20
to improve the efficiency of my GiD postprocessing stage. I decided to =
group=20
some nodal results with the keyword =93ResultGroup=94, instead of the =
=93Result=94=20
keyword I have been using so far. Following the instructions at GiD =
manual,=20
the appropriate changes in the file structure were made. However, when =
loading=20
the new =93.res=94 file in the GiD postprocessor, a Windows error =
message pops up=20
in the screen, and says =93The exception unknown software exception =
(0xc00000fd)=20
occurred in the application at location 0x007e54d7=94. Upon clicking =
in the=20
=93cancel=94 button a Visual Fortran Debugger is automatically =
initiated and=20
prompts =93unhandled exception in gid.exe: 0xC00000DF: stack =
overflow=94. I looked=20
for errors in my =93.res=94 file but I could not find any. Then I =
decided to run=20
the example from =93Help>Postprocess data files>New postprocess =
results=20
format>results example=94 and I found that the same error occurs =
when loading=20
the =93.res=94 file. Is there any tricky thing in using the keyword=20
=93ResultGroup=94??? (I am using the 7.2 version of GiD) Attached to =
this email=20
you can find the mesh file and the result file that I have been trying =
to use=20
(these are the examples from GiD manual). I appreciate very much your =
kind=20
attention, and wait for your reply as soon as=20
possible.o:p/o:p/FONT/FONT/SPAN/P
face=3D"Times New Roman"Gracias!o:p/o:p/FONT/FONT/SPAN/P
face=3D"Times New Roman"Eduardo =
Campelloo:p/o:p/FONT/FONT/SPAN/P
face=3D"Times New Roman"Department of Structural and Foundation=20
Engineeringo:p/o:p/FONT/FONT/SPAN/P
P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"FONT =
size=3D3FONT=20
face=3D"Times New Roman"University of S=E3o Paulo, S=E3o Paulo =96=20
Brazilo:p/o:p/FONT/FONT/P
face=3D"Times New Roman"Phone/Fax: 55 11 3091-5367 and 11 55=20
3091-5181o:p/o:p/FONT/FONT/SPAN/P/FONT/DIV/FONT/DIV/=
BLOCKQUOTE/BODY/HTML
------=_NextPart_000_0083_01C3B535.C1C679D0–
