I want to fill a field of data tree with the number of a point in the geometry. Is it possible to add an <edit_command> to call a function to select a point using the graphical interface?
Here is what I was trying to do, but was unable to find a tcl function to call a pick point selection:
proc SpdAux::ProcSelectPoint {domNode args} {
Tiago Valente
There is in scripts/dev_kit.tcl a procedure to facilitate the selection of GiD entities.
proc GidUtils::PickEntities { type selectmode {message {}}}
(see the comment on this file to see its arguments)
e.g.
set id [GidUtils::PickEntities Points single [= “Pick a geometry point”]]
W “the point id is $id”
On the other hand, I think that is not a good idea to add to the customLib tree an item to be filled with the id of a point. The normal way to do it probably is to use a condition that is related to a group name, and add to this group the points you want.
In any case, if do you want to implement your approach, is possible to do something like this:
In the file .spd
<container n="Points_of_loads" pn="Points of loads">
<value n="point1" pn="N. point 1" v="" string_is="integer_or_void" help="Number of the point in the geometry to attribute the value 1 of the load">
<edit_command n="select_points" pn="Select Points" proc="MyProcSelectPoint %W" icon="point"/>
</value>
</container>
and in the file <problemtype.tcl> define this procedure
(it is possible to embed the proc in the xml definition, and the the arguments are implicit, but is better to edit and debug to define the Tcl code in a Tcl file)
proc MyProcSelectPoint { dom_node } {
set my_dict ""
set id [GidUtils::PickEntities Points single [= "Pick a geometry point"]]
if { $id != "" } {
set question [$dom_node @n]
#Note: in this case we knot that question is 'point1' but this show an use of the dom_node argument
set my_dict [dict set my_dict point1 $id]
return [list $my_dict ""]
Note: the proc can return a list with a first item that is a dictionary with they - value to be changed in the entry (in this case the key is ‘point1’ and the value the entity id)
I have found another way that was not documented (we will document it)
that do something similar, simply declaring the value of fieldtype='vector, dimensions=‘1’, with attribute pick_point=‘1’
<container n="some_points" pn="some points">
<value n="some_point" pn="Some point" fieldtype="vector" dimensions="1" string_is="integer_or_void" pick_point="1" help="To enter a point"/>
</container>
Thanks for your help.
I was able to implement the solution that you pointed out.
